BimmerTim
I bought my first, and so far only, Toyota back in August 2017.
A friend and I flew one-way to Seattle from Minneapolis to find a truck to drive back. I was originally after a 2015 Ford Ranger, as I really wanted a small, manual, 4wd truck that I could TDI swap. After no luck finding a nice enough Ranger we started looking at other options, with the Tacoma as a front runner. I drove quite a few, but landed on a 1998 Xtra Cab with a ton of miles on it... I have since put another 60k mi on it driving all over the country camping and off-roading with it. My last trip was to Wyoming for a week-long off-road trip through the Black Hills, Sierra Madre, Medicine Bow, Wind River, and Big Horn mountains. The 2.7L 4-cyl 3RZ-FE is nothing to write home about, but on this trip I could tell it was really starting to feel its age. The time has come to start the TDI swap.
Since I can recall I’ve wanted a small truck with 4wd, manual, and a diesel. As far as I can tell, this doesn’t exist in the US. I did find a couple of Hilux for sale in Canada, but I wasn’t sure about importing and titling at the time. Plus, with an imported engine you run the risk of being stranded if something breaks on a trip.
I have also been into European cars for 20-ish years, and have own a couple of 2000 era TDIs. That is a plentiful engine around the US, Canda, Mexico, etc. So, I found a 1999 VW Golf TDI Automatic that was no longer acceptable for the road as a donor. In hindsight I do wish I had gotten a slightly newer TDI since the ECU is not flashable in the early cars, they use solder-in chips. The automatic was intentional, because the auto came with an 11mm injection pump where the manual only came with a 10mm injection pump. Not that I plan to hotrod it much, but it does open some doors for power.
After a few years of preparation and not wanting to take apart my truck, because I use it for camping quite often, it IS finally time. I will be attempting to be more live updating this part of the process. I’ve only been working on it for a couple of weeks, so this an update that will bring us to today.
I started by pulling the 2.7 3RZ out of the engine bay to see what I’m working with.
A very dirty engine bay. I don’t have water in my workshop, so I bought one of the portable battery pressure washers that use the same battery as my lawn tools. I would say it’s very convenient, but if you’re hoping for high performance look elsewhere. For what I need, it’s perfect. I can put in a little extra elbow grease and scrubbing if it means I can clean parts up at my shop.
I have a few 1.8t engine blocks laying around, so I decided to test fit with one of those to check oil pan to diff clearance. There wasn’t any… I also wasn’t sure what angle to set the engine at, so I ended stripping the 3RZ down and setting it back in the bay.
With the 3RZ bolted back in I made some super janky transmission locating brackets.
The transmission staying in the same place as stock will ensure that drivetrain and shifter angles all stay the same. I don’t want to stress other parts by raising the engine and changing angles if I don’t have to.
Next, I wanted to see how the TDI engine fit in the space. I had read about vacuum pump clearance issues. I was worried about the FWD turbo VNT actuator location, and I wanted to see how the oil pump would clear the front diff.
All things considered, it fits pretty well.
The vacuum pump has no issue with clearance and I could put my hand between it and the firewall.
The VNT actuator, however, is a different story. The actuator sits only about 1/2in or so from the passenger mount bracket on the frame. There is no way the stock mount is going to fit there. The stock mount would be a very tight fit, but doable on the driver side, but not with A/C in the stock golf location.
I would like to get this on the road as quickly as possible so I can start finding the bugs and working them out. I have some trips planned and I don’t want to be worrying about stupid things.
I also want to use as much of the OEM Toyota and VW parts as possible. For the A/C I have two options;
With a little research I found that in Europe the Seat Leon was offered in TDI without A/C. What this does is remove the A/C pump from the main serpentine belt on the TDI, and with the added benefit of relocating the power steering pump lower.
Here is the original TDI serpentine layout.
And here is the non-A/C Seat serpentine layout.
I also found that older Audi A4 and VW Passat 1.8t came with the A/C running on a second serpentine belt with the pump mounted on the passenger side.
The secondary serpentine belt is a 5 rib belt, which is exactly what the Toyota A/C pump is. The Audi/VW also has a tensioner system I can work with and a crank pulley that has both serpentine belt spots.
Another key is that I can now leave the A/C and pump until absolute last. If I had run the A/C on the main serpentine system I would have had to figure it out before putting miles on or risk damaging the pump.
- Redesign the driver mount to allow A/C pump and lines to fit, and have custom lines made. This is also not ideal, because the Toyota A/C is on the passenger side and the VW will be on the driver side. If the pump were to fail on the road you cannot route a belt to bypass the A/C pump without custom brackets and pulleys.
- Design a bracket to mount the Toyota A/C pump on the TDI block and find OEM VW serpentine parts to run the A/C separately.
