jramsay
I just switched my steering wheel to one with paddles. The thing is the steering wheel also has the capabilities for Active Cruise Control, which my car does not have. It does have some other codes, and the Steering Wheel Module on VCDS won't open. Currently, everything works except for the Cruise Control, and the glow plug light is flashing. Currently, no other trouble lights are on, and the car is driving fine. The other thing is the fuel mileage is reading low, which I am assuming is due to the ecu error (flashing glow plug light). I am trying to see, if there is a way in VCDS to fix this issue. Below is what I am getting with Autoscan.
Wednesday,10,May,2023,20:34:47:58437
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: 3VWLA7AJXFM339717 License Plate:
Address 01: Engine (04L 997 016 E)
20:34:35
IDE00021 Engine RPM 1165 /min
IDE00100 Engine torque 30.9 Nm
IDE00350 Air mass: specified value 250.0 mg/stroke
IDE00472 Mean injection quantity 3.91 mg/stroke
IDE04002 Charge air pressure control BP_A cmd/act:104.7/105.8 kPa
IDE07712 Turbocharger 1 turbine input: temp. sensor 1: B1: raw value 247.0 ∞C
IDE07818 Fuel high pressure sensor: actual value 380800 hPa
IDE07820 Fuel high pressure sensor: nominal value 392300 hPa
Thursday,11,January,2024,16:43:39:58437
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VCDS Release 23.11.0: Generic OBD2
Mode 1:Read Data
70:Boost Press Ctrl A/B BP_A cmd/act:95.9/100.1 kPa
71:Var. Geom. Turb. Ctrl A/B VGT_A cmd/act:100.0/99.6 % VGT_B cmd/act:---/--- % VGT_A:Closed Loop
Thursday,11,January,2024,17:01:51:58437
www.Ross-Tech.com
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 997 016 E HW: 04L 907 309 K
Component and/or Version: R4 2.0l TDI X20 9465
Software Coding: 011D0012042410084000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_ECM20TDI01104L997016E 004002 (VW36)
ROD: EV_ECM20TDI01104L997016E.rod
VCID: 353733DC05CF32F2CC5-8060
1 Fault Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [10101111] - -
[Checking coding/versions ofcontrol modules in drivetrain]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 242326 km
Date: 2024.01.11
Time: 01:36:32
Engine RPM: 2151.00 /min
Normed load value: 1.2 %
Vehicle speed: 30 km/h
Coolant temperature: 92 ∞C
Intake air temperature: 82 ∞C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: -0.742 m/s≤
Readiness: 0 0 0 0 1
Address 01: DTCs cleared
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BS HW: 1K0 907 379 BS
Component and/or Version: ESP MK60EC1 H46 0166
Software Coding: A14B400C49250003851202E592200042A1100012
Work Shop Code: WSC 00066 000 00000
VCID: 04519E181E155B7A0BB-8050
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 242321 km
Time Indication: 0
Date: 2018.06.03
Time: 01:29:60
Freeze Frame:
Count: 2
Count: 14
Count: 29184
Count: 16390
Count: 51200
Count: 0
Count: 1277
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 242321 km
Time Indication: 0
Date: 2018.06.03
Time: 01:29:60
Freeze Frame:
Count: 2
Count: 14
Count: 29184
Count: 16390
Count: 51200
Count: 0
Count: 1277
Count: 0
Address 03: DTCs cleared
Address 56: DTCs cleared
www.Ross-Tech.com
20:34:35
www.Ross-Tech.com
Mode 1:Read Data
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 242326 km
Date: 2024.01.11
Time: 01:36:32
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 242321 km
Time Indication: 0
Date: 2018.06.03
Time: 01:29:60
Freeze Frame:
Count: 2
Count: 14
Count: 29184
Count: 16390
Count: 51200
Count: 0
Count: 1277
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 242321 km
Time Indication: 0
Date: 2018.06.03
Time: 01:29:60
Freeze Frame:
Count: 2
Count: 14
Count: 29184
Count: 16390
Count: 51200
Count: 0
Count: 1277
Count: 0
