Too40gawlf
Hey Folks,
A friend of mine recently got a 98 Jetta with the 1.9 AHU that had a massive leak from the back of the injection pump. While I have a lot of experience turning wrenches, I have not messed with a TDI motor, but I was eager to jump at the opportunity to work on this car/motor. Anyway, I went over to my buddy's place a few nights ago to remove the injection pump to bring it back and re-seal it (which I have done). When removing the pump, while I did have the cam locking tool, I didnt have the crank locking tool. I marked the timing belt to the sprockets (cam, crank, and injection pump) but I dont believe I marked it to the engine block. In addition, I am not 100% sure I had the engine at TDC (cam tool fit just fine, but I couldnt see any indicator on the flywheel inspection hole, even though I turned the engine over multiple times - so i just go it to where the #1 cylinder cam lobes were pointing away from the valves and the where the cam holding tool fit snug). I guess I could theoretically be 180* out?
I'm going to go back and work on the car next week, but now I'm starting to have doubts as to getting it back to perfect timing. The cam shouldnt have moved because the tool, but Im not sure if the crank sprocket didnt rotate as I was taking the belt off. I have ordered the crank holding tool and will have it with me on re-assembly.
But my main question is, how do I ensure timing is right on if I didnt secure the crank sprocket with the tool prior to removal of the belt and if my marks where less than ideal (it was dark and i was trying to extricate the injection pump to get going)? Secondarily what other tips n tricks would you pass on to ensure that this job is done correctly?
Thanks folks - sorry for the sloppiness - it was cold and dark and I wasnt my usual slow and methodical manner.
