CR170 Upgrade
-:vw:-
Somewhere, USA
2014 SportWagen
Yep, I know there's thread up here however I have a few quick Q's.
First, what is the deal with the price difference of the actual turbo?
That is pretty considerable.
Second, as I understand it, in addition to the turbo and tune one needs the following:
This isn't on the JFettig thread but I have to believe it's needed:
Lastly is it recommended to swap out the oil supply and return lines with new? Does the new turbo require oil priming or an oil re-stricter of any sort?
Thank's.
tjg
Ft. Hood, TX
'13 TDI A3, '14 TDI Sportwagen
I'm not sure what the reason for the price difference is, I went with the tunemyeuro one when I did stage 3 on my A3. It's a brand new turbo, he might just sell for a lower profit.
You will need the egt spacer and elbow.
And yes you'll want the install kit.
I bought a braided oil feed line from darkside developments, but was able to reuse the original feed line.
I pre lubed the turbo with two tubes of turbo oil and then disconnected the injectors and turned the engine over for a few seconds to build pressure just to be safe.
No restrictor is needed that I know of.
Here's my CR170 thread. It's on an A3, but basically the same.
-:vw:-
Somewhere, USA
2014 SportWagen
Perfect thank you!
-:vw:-
Somewhere, USA
2014 SportWagen
So... Update. I'm going to be moving forward with this. Also I've been doing a lot of reading on swapping this thing out and everyone seems to be going with a bottom extraction. I found this video can anyone tell my why the top extraction wouldn't be possible??
tjg
Ft. Hood, TX
I can't see any way for the turbo to be taken out the top... there's no physical space to get it out that way. I considered it myself too.
I HIGHLY recommend removing (and deleting) the EGR cooler before taking the turbo out, it gives you A LOT more space. Additionally, I was able to manhandle it through the trans tunnel.... though if I were to do it again, I'd completely remove the passenger axle and drop it out between the motor and subframe.
-:vw:-
Somewhere, USA
2014 SportWagen
Did you watch the video he pulls it out the side/top with the battery removed.
tjg
Ft. Hood, TX
Youtube is blocked at work; I suppose it's a possibility to take it out that way... I'll watch it when I get home.
mishkaya
TDIClub Contributor
Iowa
'06 Jetta 5MT, '10 JSW MT, '14 JSW 6MT
As far as I can tell, that must be a right hand drive car mas the brake master cylinder is on the right hand side. I don't see how you could possibly get the turbo out from the front without removing the master cylinder. It would be much easier and quicker to remove the passenger axle, which gives you plenty of space to work with.
-:vw:-
Somewhere, USA
2014 SportWagen
I was looking for the steering wheel too but couldn't tell for sure. Anyone tried dropping or even pulling the subframe? That'll open up some REAL room and I'm doing suspension as well...
roadlust
Yakima, Washington
2003 golf gl reflex silver (sold) 2013 TDI 2 door Golf Blue Graphite Metallic 6MT Premium Package.
It can be taken out the top with the exhaust system and components removed.
-:vw:-
Somewhere, USA
2014 SportWagen
"I HIGHLY recommend removing (and deleting) the EGR cooler before taking the turbo out "
Regarding this. I was looking at it and it seems pretty straight forward while "I'm in there".
My question is do I need to buy anything extra or can I just use the blanking plates on the turbo manifold and egr port on the intake manifold???
I stared digging into it last night. I've got everything on the top pulled apart for the DPF and Turbo. The "D" electrical clips are a product of SATAN however, I jacked up the one going to the EGT on the turbo manifold pretty well :mad:
mishkaya
TDIClub Contributor
Iowa
I believe you will need a hose barb splice for the heater core hoses. Should be available at your local hardware store
-:vw:-
Somewhere, USA
2014 SportWagen
What about the EGR tube connected to the intake manifold? Wont that be a massive leak if not removed and capped?
mishkaya
TDIClub Contributor
Iowa
I believe you are correct, car I had worked on had a race pipe installed, so it was not a concern.
-:vw:-
Somewhere, USA
2014 SportWagen
So... the kits for this are all over the place. There is one with the race pipe (DarkSide), which solves the intake port issue. However there are other delete kits with only two block off plates for the back of the engine when in reality you need three, two for the back and one for the intake?
Very confusing.
tjg
Ft. Hood, TX
I went with the darkside kit, primarily because deleting the EGR valve on the intake makes it easier to install the CP3 fuel pump.
That being said, actually removing that EGR pipe from the engine bay is a whole different animal because it has a decent amount of things on top of it. On both my A3 and Sportwagen I just zip tied it out of the way until I feel like either digging it out properly or cutting it into 2 or 3 pieces to take out.
Additionally, installing the blockoff plate on the manifold is FAR easier to do on the bench than while it's in the engine bay.
Finally, removing that system will go a long way in reducing intercooler icing risks. Even when you have the EGR disabled with a tune, that pipe is still receiving exhaust gasses and transferring heat to the intake system.
And another note; Darkside will send you a straight coolant connector. I prefer using a 90 degree one.
-:vw:-
Somewhere, USA
2014 SportWagen
Diameter on the hose barb for the coolant and the remaining question.
Do i need a block off plate for the EGR port on the intake? If so is it the same size as the others?
Also something I forgot to mention above to those looking to tear into theirs. Bring your toolbox A GAME! VAG has used every damn bolt type possible securing this thing to the back of the engine. Alens, stars, tripple squares, flat heads, philips, you name it it's one there! ZERO consistancy.
mishkaya
TDIClub Contributor
Iowa
All block off plates are the same size as I recall. Cam't check on the hose barb size until I get back from work this evening.
mishkaya
TDIClub Contributor
Iowa
According to the caliper, the outide measurement of the barbed fitting was .857", whatever that is supposed to correspond to...
-:vw:-
Somewhere, USA
2014 SportWagen
Without converting I'm going with 7/8" barb. I'm about 10 hours into this after two evenings worth of work. Everything on top is disconnected removed and the exhaust is now out. I have some interesting findings to report... Fist this is my EGR "Filter"???
What the F&$K is THAT? This car has had the "fix" according to the VIN lookup I'm not sure if that added or removed the "filter" but mine looks NOTHING like the others I've seen.
Second. Whatever clown worked on the car before I acquired it didn't put the axel shield back on... ?
Does anyone have a part number for it. It should probably be there... ?
To get everything out so far I have dropped the subframe. I would literally pay (within reason) to watch someone do it without dropping it...
It fought me several hours even with the added space.
tjg
Ft. Hood, TX
That EGR pipe was on both my A3 and sportwagen... notice that it's different than what Rawtek shows in their guide.
Neither of my fixed vehicles had the axle shield either.
Both of my deletes were done without dropping the subframe. The second time went much more smoothly.
-:vw:-
Somewhere, USA
2014 SportWagen
Hahaha! So your telling me there is a axle shield bandit on the loose?
I'm really not sure what the EGR pipe is about but I guess if yours had it there is some rhyme or reason to things.
I ended up with two 1" brass elbows for the EGR coolant lines. I'm not sure how everyone got only one to work on theirs, with one it severely kinked the coolant hoses. I used two and another small piece of 3/4" coolant hose to form a "U" in the run.
Everything is now pulled except for the turbo. That should come out today through the tunnel.
My garage looks like a tool bomb went off. Stuff is everywhere.
-:vw:-
Somewhere, USA
2014 SportWagen
Whelp. Modfest 2020 is complete. A full list of everything done is:
  • C170 Turbo
  • Buzzken pipe.
  • Malone Stage III Tune
  • H&R Sport Springs
  • Bilstein Touring Dampers with new front strut bearings
  • 25mm Rear Sway Bar
  • Jetta GLI steering wheel with paddles
  • Black Forest wheel spacers 15mm front 20mm rear
I've got a few questions for you all regarding some codes I'm getting after doing the work and having the battery disconnected. I have no idea why on gods earth many of these are popping up:
  1. Engine - 000175 - Actuator Module for Turbocharger 1 - Fairly certain I had vacuum lines on the n75 jacked up this should be good to go.
  2. Trans - 28907 - No Communications with Cruise Control (Front) Distance Sensor - ???
  3. Trans - 18258 - Powertrain Data Bus P1850 - 000 - Missing Message from ECU - Intermittent - ???
  4. Trans - 01196 - Engine-Transmission Data Bus 004 - No Signal/Communication - Intermittent - ???
  5. Brakes - 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent
  6. Brakes -01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication
  7. HVAC - 13701376 - Function Restricted due to Missing Message(s) U1111 00 [008] - -
  8. Instruments - 12648448 - Function Restricted due to Missing Message(s) U1111 00 [008]
  9. CAN Gateway - 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent
  10. CAN Gateway - 03272 - Control Module for Audio Interface 004 - No Signal/Communication - The radio was off???
  11. Navigation - 1048629 - Aux IN Socket B1104 13 [009] - Open Circuit
  12. Navigation - 1048660 - Function Restricted due to Missing Message(s)
  13. Navigation - 1048669 - Tuner for Satellite Radio B11CF 53 [009] - Deactivated - Ok, I don't pay for this.
  14. Driver Door - 68108 - Function Restricted due to Missing Message(s) U1111 00 [008]
  15. Steering Assist - 03803 - Steering Angle Sensor for Steering Aid
  16. Steering assist - 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent
  17. Passenger Door - 68108 - Function Restricted due to Missing Message(s) U1111 00 [00
I've yet to actually drive the car due to some of these. I've primed the turbo by disconnecting the injectors and fired it up and let it idle for 15 minutes or so while I scratched my head on these code.
Car is still up on ramps so far no leaks anywhere in the system thank fully.
-:vw:-
Somewhere, USA
2014 SportWagen
Regarding the errors, just kidding, apparently putting the damn thing in drive made all of them clear out 🥴
So far so good runs well. Haven't beat on it yet as I want to give the turbo a few heat cycles first.
Question on the Buzzken. Has anyone gone with the CAT option. Curious if it helps with the odor at all ;)
tjg
Ft. Hood, TX
You might want to also look into a dogbone insert as I've heard it can help prevent the dogbone from breaking. I've heard it's a weak point
-:vw:-
Somewhere, USA
2014 SportWagen
I did the stage .5 (or whatever) from BFI when I had the Stage II tune.
We're good there (y). I hear a lot of complaints regarding the vibration is adds however I'm fine with it.
I suppose you could always make it a .25 or .15 and cut a leg or two off the insert :D
