dernster57
I have an 06 Jetta with BRM motor. It is getting the following error when going into limp mode:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 317802 km
Time Indication: 0
Date: 2000.00.00
Time: 17:09:39
Freeze Frame:
RPM: 2793 /min
Speed: 82.0 km/h
Load: 100.0 %
Voltage: 14.36 V
Bin. Bits: 00101000
Absolute Pres.: 2029.8 mbar
Absolute Pres.: 1387.2 mbar
There are no vacuum leaks. The turbo actuator starts it motion with 3-4 lbs of vacuum and stops at about 8-9 lbs of vacuum. It operates smoothly and has no sticking points. The tandem pump was recently replaced. I just installed a new N75 regulator. The air filter is also new. I am at a loss as to what to check. next. Any thoughts or suggestions would be greatly appreciated.
Thanks,
Denny Ernster
owner of:
98 beetle
01 beetle
06 jetta
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 317802 km
Time Indication: 0
Date: 2000.00.00
Time: 17:09:39
Freeze Frame:
RPM: 2793 /min
Speed: 82.0 km/h
Load: 100.0 %
Voltage: 14.36 V
Bin. Bits: 00101000
Thanks,
Denny Ernster
owner of:
98 beetle
01 beetle
06 jetta
